bad transformer ?
plumbest
Member Posts: 1
in Oil Heating
why does the motor stop when I lift open the transformer on the burner.
Wiring Issue
A loose connection perhaps?0 -
bad transformer?
Is it actually that the motor wont start until you close the transformer? If the cad cell sees light it will not let the burner start, once you close the transformer the cad cell is in darkness and the burner will start.0
