Difference in Vaporstats?
Patrick_North
Member Posts: 249
So... Honeywell offers a 0-16 oz vaporstat and a 0-4lbs vaporstat. Obviously I only need the 0-16oz for my one pipe steam setup, but will it perform any better at lower pressure than the 0-16ounce?
(Yes, the real question is: is it worth the hassle to send back?)
Thanks,
Patrick
Thanks,
Patrick
vaporstat selection
if you have a choice, go with the 0-16 oz. if no choice, then 0-4 PSI will work, but will require a bit more adjustment, as this vaporstat can still over pressure the system, and will not be as accurate at the lowest pressures as the other.--nbc0 -
Vaporstats
Hi Pat -
Here's some notes I made on vaporstats a while back that might be of help.
- Rod0 -
Thanks, guys!
This helps.
Patrick0
