Pressuretrol to Modulate a Vapor System???
Gman_3
Gman_3 Member Posts: 27
Can anyone recommend a replacement for the discontinued Honeywell L91B-1019 pressuretrol to modulate a burner on a vapor steam system from 0 to 10 ounces (NOT lbs)? The new 1035 model goes from 0 to 15 lbs which is not designed to modulate solely in the 0 to 10 OZ range.
Any thoughts on where to find a manufacturer's substitute or even surplus unit?
Thanks!  Gman
