Old Radiators, New Boiler, and Slime & Sediment
LannyW
LannyW Member Posts: 2
My partner and I are
planning to use a Triangle Tube Combi condensing boiler to supply 18 big, old
radiators, some existing hydronic baseboard (3/4 copper), some new radiant
(pex), and DHW.  We are well on our
way to designing for the various temperature and volume requirements (but would
welcome any bright ideas).  What we’re
really wondering about is . . .
Will there be a problem with
that old black slimy water typical of old systems (think gravity, coal, then
oil, then pellets and gas)?
We were leaning toward using a hydraulic separator.  Now we’re wondering if we should
provide true mechanical isolation with something such as an indirect tank with
the domestic side supplying the radiator zones.  We don't want to compromise the efficiency or functionality
of the new system.  Any thoughts on
what the old oily residues will do to the heat source heat exchanger in the
boiler, or to the mixing valve for the radiant, or to any other new
component?  We're planning home
runs for the radiators.  Any good
ideas for flushing the radiators out?
  • Wyrm
    Wyrm Member Posts: 1
    edited September 2009
    heat exchanger?
    why not just use a heat exchanger so you're not fouling up the new boilers.  It might cost a little more up front but a heat exchanger is cheaper than replacing a damaged boiler.
    Use the heat exchangers between the boiler and the old radiators.
    The DHW should be clean, as would the new radiant pex
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    New system tips
    I'd recommend you consider using a cleaning chemical before commisioning the new boiler. Purge valves on the returns will allow flushing of the sludge.  You may have problems withg the system if you don't clean it.  Rhomar makes an excellent product.  I'd be using a hydraulic separator and changing all of the existing radiator valves to TRV's.  A system using the new variable speed pumps will really perform!
