New Home / Old Boiler-Burner
NShak
NShak Member Posts: 38
A friend bought a "new home" that has a Burnham RS-111 boiler-burner.  We've learned that it has a tankless coil heating element for the house's hot water.  We're not clear on how the steam heat works- radiators throughout the house are 2-pipe.  I'm assuming this is steam; could it actually be hot water heated radiators?  It also has an expansion tank which we're not clear how that works either.  Can anybody help us figure out how this kind of system works?  Thanks in advance.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    That's
    That's a steel dry base oil fired hot water boiler.Check out the systems link at the top of the page.You have a hot water system with a very inefficient boiler
