80 Gallon oil-fired water heater
Hygrade
Member Posts: 1
in Oil Heating
Help!! Need to find replacement for a Phase 3 80 gallon oil fired water heater.
I want some other options other then the Bock 70E
Boiler is better
I would replace it with a boiler.0 -
You may want to try one of these
heat pump water heaters. Rheem makes one and also Stiebel-eltron. http://www.stiebel-eltron-usa.com/accelera.html0
- 116 Geothermal
- 169 Indoor-Air Quality
