Raditor Threads not matching
PhillyRow
Member Posts: 2
Hello,
This is my first post. I recently bought a 1930's house with one-pipe steam, so I am still a novice.
Last week, I bought some radiators on craigslist to replace some smaller ones that were under-performing.
But, when I got them into place and tried to connect them to the (angle intake) valve, the threads do not seem to match. The difference on one is so slight that it seems to tighten, only to slip at the last minute. The other will not begin to thread, but is very close.
I see that the angle valves come in different sizes, but the difference does not seem to be 1/4". What do I need to do to be able to use these replacement radiators?
I appreciate any suggestions. Thanks.
Angle valves
Angle valves come with 3 parts: valve, nut and spud. The threads on the valve (where you screw on the nut) are not standardized and differ with manufacturers. You will need to remove the spud and nut from the radiator and use the one that is correctly mated with a valve. I'd go buy a new valve.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thank you
This was a quick and clear reply.
Thank you.0 -
underperforming radiators
how were some of the radiators "underperforming"? it is unlikely that they are clogged with debris, so there must be some other issue. check your main line and radiator] venting, to make sure that the supply is not airbound as steam is rising. also check your pressure to make sure it is not set so high as to prevent the vents from doing their job. do this before spending more money on the radiators that instead should probably go towards new vents.
you would certainly benefit from a copy of "the lost art of steam heating", available here. this will point you in the right direction when problems arise, and prevent you from barking up the wrong tree, as may be the case here.--nbc0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
