Converting from oil to gas
a steam or hot-water system? How many sections are in this boiler (for example if 4 sections it's a 4-78)? What is the firing rate?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • BRIANJ
    BRIANJ Member Posts: 118
    Can an oil fired Series 78 Weil McLain boiler with Beckett burner be adapted to low-hi-low heating? If not oil what gas burner would be recommended for the conversion? Thanks for your help.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,368
    Outdoor Reset
    Instead of regulating btus though input , you can through output with a outdoor reset control .. Will increase home comfort on a hydronic system .
