converting radiators
chris_68
I have a chance to get a bunch of old cast iron radiators set up for single pipe steam. I'd like to use them in my house at some point (years from now) for a hot water system yet to be installed (I don't have central heat at the moment, just a woodstove, located in Maine).
Of course to convert them to a two pipe system, I would have to remove one of the plugs in the radiator which has been in place for who knows how many years in a town with not great water.
Will these plugs even come out so that I could convert them into two pipe radiators? What if any tricks could be used for this? Any other thoughts? Could I drill and tap them, since I would only need a 1/2 inch line? Thanks for your ideas.
Some steam radiators
cannot be used for hot-water at all. Post a pic of the different types you have and we can tell you for sure......
Radiator valves
Chris,
I believe Oventrop (among others) makes a single penetration radiator valve just for that purpose, eliminating the need for knuckle-breaking plug removal. Check out any wholesaler in your area.
Good Luck,
Bill0 -
BoilerBilll
Good idea,, but I think the ones Frank(Steamhead) is speaking-of will not permit those same tapping inlet valves to work properly, as the rad should be "open" across the top.
Dave0
- 133 Chimneys & Flues
