Patterson Kelly MACH boilers
Ron Miller_2
Member Posts: 5
Regarding the Patterson Kelly MACH series commercial condensing boilers. Does anyone have experience with these boilers. They are specified on a job and I have not used them.
Ron
Ron
Our shop just installed 4 in a seniors high rise. Make sure you have enough gas, we had a bad reg. oops. We had a factory trained tech do the startup as part of the quote. So far they seem nice. Post a sign somewhere about maintaining ph and water quality because of the aluminum block. Let the boilers control the boiler pumps, not the bms. You can force the boilers to fire without the pumps running if the bms controls the pumps. High limit has a manual reset inside the cabinet.0
- 120 Geothermal
