how ca u tell if u have a faulty t&p relief valve?
ken wagner
how can u tell if u have a faulty t&p relief valve??
If it
leaks when both temp and pressure are below the valve specs.Do you have a pressure gauge?0 -
Maybe its faulty
tttttttttrhTHE OTHER WAYt0 -
If it
will not open and shut properly when tested.
Bergy0 -
change it out
just change it . they cost peanuts. ulta cheap insurance0 -
The worst way
to find out is when you see your water heater on the lawn and a big hole in your roof.0
- 133 Chimneys & Flues
