Cleaning oil burner nozzles?
Al Letellier_9
Member Posts: 929
Don't do it. They only cost a few buck and you could alter the nozzle by cleaning it. You would accept liability as well and it isn't worth it.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Can or should oil burner nozzles be cleaned?
I was checking out my oil furnance last night and I noticed an used oil nozzle left on the unit. It occurred to me that since I have access to an ultrasonic cleaner at work, I could try cleaning the nozzle in some 409 or equivalent. Obviously I would not use any drills or pins to deform the precision machining in the nozzle.
Can nozzles be cleaned this way? Does it make sense to do this IF the service tech determines that the nozzle is appropriate for the burner? What do you folks do with the nozzles removed from client's boilers?
Just curious.
Larry C0 -
nozzles
As Al said, there is no cleaning of oil nozzles, only replacing them. That's like having the oil changed on your car and not replacing the filter. Start fresh with all new filters, strainers, and nozzle to assure correct spray patern and atomization. peace0 -
wouldn't...
address wear to the orifice, though it might clean it if the right cleaner or solvent was used, and given that they're only a few bucks each wouldn't be worth it anyway.0 -
I have a few used spark plugs you can clean0 -
A lot of old timers would leave an old nozzle near the boiler "in case" the nozzle would clog up at night and they didn't have one. I always take the old nozzles with me when I leave a job. It was bad enough to be removed from service, Why would I want to put it back into service??0 -
ouch
Dan G, he may be thinking green? I can almost see the recycle aspect, but not with something so critical. By all means, the metal/brass can be recycled. peace0 -
in a pinch i will and have cleaned them --if its an odd-ball spray or the desired nozzle was not available ---but i will replace them soon after --and leave an extra 1 for next time0 -
nozzels
Never buy one nozzel, buy two. Install one and put the other unused one in a can of clean Kero and forget about it!Then when the old nozzel is plugged install the kero filled nozzel and do not forget to replace the one you removed.0 -
Kero
Milt, that would be a great idea if the dye in the kero wouldn't eventually create a whole other problem. I would say diesel or WD-40. peace0 -
why not?
why not just keep it in the plastic case the manufacturer
provides??????0 -
that's what should be done
But if someone feels the need to remove the nozzle and throw out the container, than it should be protected somehow. peace0 -
The problem with oil nozzles is not just the orifice itself but the sintered bronze screen clogging up reducing flow. You will never remove that crud. You're talking particles less than 10 microns.
As noted, why when they are so cheap?
I recommend every installation keep one spare nozzle and filter in original packaging stored nearby. That way when you have a no heat call at 2am with a foot of snow and the last of your supplies used up on your truck with no supply houses open, the two most common replaceable parts are already there.
Bob0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
