Radiator H V alve
radmix
Member Posts: 194
Im looking for a company that sells Radiator H Valves with immersion pipe for a single pipe radiator horizontal connection. Im converting a single pipe steam radiator to a hot water system and do not want to go through the trouble of breaking the tapings on the other side. I did see one at ISH the companys name was Heimeier but all searches leed me to Germany with no American outlets.
make your own with a double tapped bushing0 -
Danfoss
Try Danfoss.0 -
I use the copper
I use the reducing copper tee for supply/return connection at one end of radiator..0 -
Does your radiator
have push nipple connections on the tops of the sections as well as the bottom? If not, it won't work on hot-water.
