How do you add attachments ?
  • Rod Kotiga
    Rod Kotiga Posts: 68
    Do you need to have a program to send attachments with your posts or am I missing something easy here ?
    Rod
  • Attachments
    Rod,
    When you are typing your message, there is a button that says "Attachments" at the bottom left of the orange box. Click on that and then click "Browse" Find the file you want to attach and then click the "Attach" button to the right of the "browse" button. Then click "ok" after the file shows up in the box. Some types of files are not allowed, but any image file or pdf should work fine.
  • Rod Kotiga
    Thanks Andrew !!
