Bought house with oil heating, Willing to upgrade
Al Letellier_21
Member Posts: 400
have a competent heat tech or company do an evaluation of your ductwork. If it is large enough to handle the A/C, consider going hydro-air. You can remove the furnace, install a fan coil unit with both heating and cooling coils, and install a condensing gas or high efficiency oil boiler to provide the BTU.....another question to ask yourself: just how often will I need to use the A/D. Maybe just running the fan will keep air moving in the house on those few days you really need to cool things down.
My 2 cents worth
My 2 cents worth
house with oil heating. Willing to upgrade
Hi, guys,
I just bought a place with oil heating and I want to upgrade or add cooling. I suspect this questions is asked over and over but I did a search without results. I hope my question doesn't bother you.
Facts:
Location: Montreal, QC (cold winters and humid summers, reaching 86F 12 days on average)
Ducts and furnace in place.
Oil tank to be replaced
Oil heated water tank
Previous owner used window' A/C units
I was thinking in adding a heat pump but a contractor told me to use central A/C, and replace the oil heating for electricity (including water tank).
I know it goes to energy vs. oil prices... And equipment prices, but, in your educated opinion, what would be the way to go? Thanks0 -
Kerr
has a new condensing oil furnace,and it's made in Canada!
http://canmetenergy-canmetenergie.nrcan-rncan.gc.ca/eng/industrial_processes/industrial_energy_systems/publications/200872To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Thank you guys... I will read more about efficient oil furnaces0 -
here is what I would do
I would install a DAIKIN system
forget paying for oil. no need for back up electric heat
inverter compressor and electronic expainsion valve and they run at a minimum 15 seer but more like 20+ most of the time.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
