baseboard radiation
Al Letellier_21
Member Posts: 400
Anybody remember Sun Tec baseboard radiation? Who made it and is it dead and gone? My brother is a PM for a large mechanical and they need to match some up. Anything out there come close??
are you sure
it's not sun temp that you have and are looking for?0 -
baseboard
It may be but bro said sun tech????
What do you know about either/or ???0 -
sun something
Al, I think he may be thinking suntec fuel pump?? I've only seen Sun Temp in the field, and not sure if you can still find it. I think Sterling is close to it if you are trying to match something up. Sometimes it's best to replace the whole run. When the fins are plugged or bent, it won't heat well. peace0 -
baseboard
Thanks for the reply, but problem solved. It is SunTemp and its made by Sterling. Have a wholesaler and the distributor right here in So. Portland.
AL0
