condensing boiler steel or aluminum?
john g_5
Member Posts: 5
which is a better heat exchanger for ng condensing boilers stainless steel or aluminum? I have heard aluminum is more prone to thermal shock which can crack the unit.
I'm getting sold on the Triangle Tube - Stainless HX
Am looking to install the triangle tube prestige. took the factory training - impressive equipment along with the Smart Indirect - with stainless tank within a tank design.0 -
I have somewhere around 30+ of the Triangle Tube prestige
boilers in. 10 - 399s and the rest 110s and 175s. Tim0 -
love the TT's
Nice. What if any recurring problems have you encountered? Ever use the Smart Indirect? what do you expect the life to be on the Prestige Solos if properly maintained? I just love the 'fire tube' stainless steel exchanger and the Smart Indirect - stainless tank in a tank - ingenious designs.0
- 167 Indoor-Air Quality
