isolating floors for heating
technically heating
Member Posts: 1
are there valves to isolate upper floors of building from heat in a steam system while allowing the first floor to be heated.
are you asking the lady sparky ?
Are ya asking the lady sparky with steam heating problem? You are in the wrong thread. Try reposting this and its your venting is causing the un even heating between the floors... and other things too, can youpost some pictures of your bolier and system?0 -
- 117 Geothermal
