hot tub
Need a control valve to deliver setpoint water temp to an outdoor hot tub. We are running the tub water (400 gallons)thru a stainless plate heat exchanger connected to an Ultra boiler w/3 other very small zones. The tub touch pad needs to communicate with a control valve. Any thoughts on a control valve?
how Now?
brown cow?
how does the existing system do it?0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
