questions
tony C
Member Posts: 1
where would you even find these books for these types of questions.
technical questions any help would be appreciated
1 the maximum gas pressure that can be supplied to a water heater gas valve is ___ water column
27.6"
7"
13.8"
2 the manifold gas pressure for all water heaters is
A the same
B different depending on fule types
C regulated by the gas valve
D both B and C
E both A and B
3 pressure readings in a power vent water heater vent are made using a ________
a slack tube or a digital manometer
4 The primary combustion products of burning natural or propane gas are heat,carbon dioxide and
A water
B vapor
13.8" , D , Draft gauge , the last one is a trick question , I would say A&BThere was an error rendering this rich post.
Read the books !
We ain't here to take your tests for you! Chris0 -
wow.....another potential Wallie has been blasted right off the map. He was just asking a simple question. Not sure why I even lurk here anymore.0 -
14" is the max pressure in wc. B and C is #2. A manometer is what you measure differential pressures with. And finally the byproducts of combustion include water vapor.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
