clogged DHW coil
Alan R. Mercurio_3
Acid treatment by a professional and only after its determined that mineral build up is the cause.
Your friend in the industry,
Alan R. Mercurio
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=408&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Alan R. Mercurio
clogged DHW coil
Whats the best way to clean out a coil that barely trickles water out of the hot outlet, will compressed air work or do I stand a chance of pitting the coil0 -
And then test your water hardness to determine if you need a softener to prevent this happening again and again.0 -
Better than half the time, the acid will reveal pin holes in the coil and you will end up wasting the money on the treatment and having to buy another coil. Better, no way better to ditch the coil and have an indirect installed. In the short run, it will give you plenty of hot water and cut your oil bill at the same time because the boiler will not have to run at 160 or more all year round just to make hot water. While you are at it you may as well have a boiler reset control installed and save even more bucks.0 -
you need a new coil ---and you need a water softener --no matter what you use to make your hot water --YOU WILL still have the issue of lime,calcium build-up --whether its a plate exchanger,coil in boiler or indirect you will still get a fouled exchanger -----either you will end up with no pressure or no heat exchange ----you NEED to deal with your water quality0 -
Put in a gas -fired water heater & call it a day0 -
Amen, and some great advice!
Alan R. Mercurio
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
Good point and great advice!
Alan R. Mercurio
Thank God Gas fired water heaters are immune to mineral build up ;-)
Alan R. Mercurio
Are you sure?
Might be a screw head, or solder in a flow restrictor at the coil inlet. If it is the coil, have it replaced. Also consider a whole house water filter/softener system. peace0 -
A safe way to clean your coil
I have used a product called Rydlyme to clean heat exchangers on indirects. It will will make the inside of the coil look like brand new. It is non-toxic. You can even dump it down the drain - legally - it is that safe to use. It is about $100.00 for a five gallon container.
Darin0 -
you won't block an indirect with anything because it will contain only boiler water(dead) water.any "stuff" in the domestic will end up at the bottom of the tank to be drained off every so often.
Peace
Matthew0 -
> often. Peace Matthew
BUT YOU WILL CLOG THE FINS ON THE HEAT EXCHANGER--reducing your heat transfer0
- 133 Chimneys & Flues
