suggestions for making this better...
Timco
Member Posts: 3,040
This was the solution for fixing a pipe in the driveway the previous guy hit when he installed this sensor. Any thoughts on making it better? It is in a $4-5 mil house and looks really bad in the front drive..I will start with a diamond, but does it need to go all the way to the ground?
Tim
Tim
Just a guy running some pipes.
4-5 Million $ Fix
A thick piece of tile or granite in the appropriate shape would impress me if I owned a 4 to 5 million dollar home.
Looks like you've poured in some concrete that would make a nice base for the fix.
Good luck....JP0 -
I did not pour this, it is the finished product of the previous guy. I was asked to make it look good. I am thinking about chipping out all the new cement, and cutting a diamond in the top 1" and chipping down from there CAREFULLY. Then the expansion joint material and a nice finish. Just looking for any thoughts on needing to chip all the way down, or could I just make the top 2" nice & square...
TimJust a guy running some pipes.0 -
brick design pattern
how about some herringbone brick work or pavers. you need a knowledgeable mason.0 -
I would not...
... cut all the way through as it would allow whatever work you do to shift with the weight of a vehicle. Cut down enough only to set some nice paver on top. Would it make sense to leave it removable for future access to the sensor?
Yours, Larry0 -
Mason
I second the idea of hiring a mason. It would be easy to spend a lot of time on this and only marginally improve the appearance. I definitely would not trust myself to repair something like this.
don't make it nice-----make it a masterpiece0 -
Boy...
that DOES look like crap.
Seeings as how money is obviously not an issue, I concur with the others. I'd hire the finest stone mason money can buy and have him set it in granite or marble or some other highly conductive, attractive stone. I think I'd also do away with the asphaltic expansion joint. If there isn't a lot of tubing below that area, the expansion joint could work against you in the way of extended run times. But, then again, if they could just burn money to melt the snow, what's the difference ;-)
ME0 -
Perhaps
A concrete grinder would dress that up enough to allow for some sealer to be added. We used to use this technique when there was over pour at sewage plants etc. Many times the finished product looked like terraza.0
- 167 Indoor-Air Quality
