Burnham V8 vs V8H
scrook_3
is done at 13.0% CO2 for #2 oil -- meanwhile, in the real world your mileage will be a little lower, pinner or 3 pass.
Burnham V8 vs V8H
Is there a differance?0 -
burnham
Maybe one leaks and the other one doesn't? Just kidding. I see no difference. I think it's just a model change thing. They are identical from what I see. peace0 -
Looks like the \"H\" is for......................
"High" Efficiency Oil-fired Boiler
85+% AFUE ENERGY STAR® Certified
Never would've through a pin boiler could be so high {wink,wink}0 -
Is that for real John?
I looked quickly, and read what was on the front page, and I must have missed it. That is rather high efficiency for a top flue pin. Time will indeed tell. peace0 -
85.3 to be precise
for a V84 we installed today .
My own pin style Peerless is rated at 87.5
Go figure
high efficiecy
You must have a WB with a Riello Ron? Don't let the triple pass boys hear that you can get those numbers with pin boilers. I know you can, but we always did it that way. peace0 -
Blanket
The First One I Installed I Noticed It Did Not Have A Blanket On The Bottom. Checked With Burnham Was Told Unless It Was For Steam It Was Not Needed. Also The Circulator And Burner Are Unassemeled. royboy0
- 133 Chimneys & Flues
