Low temperature Tridicator
Simply Rad_2
When using Ground source heat pumps I have had trouble finding low temperature Tridicators.
Ideally as low as 20F. I would like to keep the dial in the middle of the gauge instead of on the edge.
Thanks
Jeffrey
Thanks
Jeffrey
Low range Thermometers
Clamp on, direct reading in fluid, or remote reading in fluid. McMaster-Carr prices range from $50 to $150 depending on dial size.0
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
