Test Gauges
Try here; http://www.gaugestore.com/<BR><BR>Dave
Test Gauges
I am trying to buy vac and press, gauges. Can someone tell me where I can find some.0 -
Grainger?
maybe?0 -
westwood products has an all in one set. very nice0 -
> nice
Could you give me the name off of this or a site to go to to buy it. Buying useable gauges for the suntec is awful. Will this set have an adaptor for Riello?0 -
someone's posting under my name and email address
I didn't send the westwood info. Could be unintentional or April Fool's joke......
good luck...0 -
usually,
incorrect poster's names are caused by cookie issues. Someone needs to toss their cookies.0 -
Riello makes a pressure/vacuum gauge set
that is really slick. You can also get from Westwood adapters that will adapt the Riello kit to any NPT thread seen on Suntec or Webster pump. Really nice liquid filled gauges. Use them all the time.
rocky0 -
> the time. rocky
> the time. rocky
Where do I get the adaptors. I would like to make sure tha this is the case before I buy the t25 correct?0 -
> the time. rocky
Sid Harveys
or R.E. Micheals will have them.
echo
Sid Harvey. Aint much you can't get from them0 -
Test Manifold
Sid Harvey has a test manifold made for them It has the presure and vacume gauges on it and comes with the adaptors for Realio, and adaptors for 3/8 & 1/2 flare for the vacume the vacume lines are clear so you can watch for air bubbles. It all comes ina plastic carring case. They don't show it in their current catalog. It's under the Sid Harvey brand name. You can call Bill at the distribution center at 800-342-7839 or 570-830-4323 Ask for Bill tell him you want the Sid Harvey oil test manifold that isn't in the catalog for pressure and vacume. The one Mark from K&M bought for Dave before leaving for France the first week of January.
The k
Kwik Check makess a good unit you have to buy two seperate units one for pressure and one for vacume. Sid Harvey and R.E. Michal both carry them. The Sid Harvy Manifold incorporates both unints into one like our refrigeration gauage manifold sets it is convient.
Mark0 -
mc-master-carr has a serious selection0 -
Thank you very much the gauges will be hear mon.0
- 119 Chimneys & Flues
- 76 Pipe Deterioration
