Replacement Combustion Chamber
Big Ed_4
Big Ed_4 Member Posts: 3,530
The resent few chambers came with better puddy. The old stuff stuck to everything other then the cast plate. I use to use spray adheasive and KO wool strips instead of that stuff. It did not work.
  • Jim_47
    Jim_47 Member Posts: 244
    Combustion Chambers
    Has anyone used the replacement combustion chambers from Lynn? The one I am particularly frustrated with is th Lynn chamber kit for the Weil Mclain model 68 boiler. The did a fantastic job in changing to a wet wall for the rear of the boiler. That makes the rear wall installation really tight and nice looking. My problem with Lynn is the goo they provide in the kit to seal the front plate to the boiler. There is no way this stuff comes off the wax paper without breaking apart or if you get any dust on it it will not stick to the cast iron. How about something in a tube? I am very frustrated here with this since I do 4-6 a year. Anty recomendations will be appreciated.
  • john_192
    john_192 Member Posts: 1
    Lynn Chamber Kits
    Using throw away gloves,pour a little of the water glass on the putty, it makes the job a bit easier. Good Luck
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    We like
    the hi-temp red silicone caulk for sealing those front plates- and flue collectors, cleanout covers, etc. As long as it's not directly exposed to the flame, it's fine.
    You could also use the old standby, furnace cement, but the silicone is a lot neater and I think the silicone seal will last longer.
    "Steamhead"
  • John@Reliable_14
    John@Reliable_14 Member Posts: 171
    Only one easy quick way.............
    hi-temp red silicone caulking from a caulking gun. One tube will do 5 or more jobs. I never even open that putty stuff anymore.
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Honestly,
    I can say I've never used that monkey rope after the first time trying to get if off the wax paper.
    However, I tried a few things and found a combination of what Steamhead mentioned(high temp. silicone)and another Lynn product. 3/8" Kaowool rope, available in 25' sections and bagged, works the best.
    That's what they use on the "Gold" boilers from the factory.
    Bell Simons carries it and I'm sure anyone who gets chamber kits from Lynn products will be able to obtain it. Chris
  • billtwocase
    billtwocase Member Posts: 2,384
    chamber kits
    The guys know it. High temp silicone, rope, or furnace cement. The putty just drys up and falls out anyway. peace
  • Jim_47
    Ya gotta WONDER....
    Does anyone from LYNN combustion visit this web site?
  • jim dowling_2
    jim dowling_2 Member Posts: 15
    I like the idea of using high temp. silicone in the tube. The Max. temp. on silicone is only about 400 deg. if i'm not mistaken. Does it drip and run with oil boilers high temps?
  • billtwocase
    silicone
    Jim, it will hold up just fine. Flue collectors, boiler plates have been sealed this way for years. peace
  • Jim_64
    Jim_64 Member Posts: 253
    don't use the "goo"
    use rtv high temp silicone
  • tommyoil
    tommyoil Member Posts: 612
    I've mentioned this before........
    so here we go again. PLEASE, for this job throw the silicone tubes, and putty, and paste, and whatever else youre using in the garbage. Go get yourself a can of the spray adhesive 3-m makes. Clean out the groove where the so-called putty is intented to go. Spray the groove with the adhesive and allow about 3-5 minutes for it to "tack up". After its tacky,press in a cut to size piece of some 3/8" thermorope. I then take the spray can and roll it over the rope to get it set in the groove. I used that putty s**t ONE TIME and NEVER used it again. Its totally inadequate for the job. I DO however have a GIANT ball of it in my truck. Kind of like a rubber band ball. Quit screwing around with putty and silicone. I've found this to be the simplest and most effective way of dealing with this. 20+ years using this method has been all the proof I need. IT WORKS!
  • tommyoil
  • tommyoil
    Sorry....
    for the double click.
  • scrook_2
    scrook_2 Member Posts: 610
    which 3M spray?
    "can of the spray adhesive 3-m makes..."
    Which # 3M spray product? They make a ton of different adhesives!
