GB142 dP?
Jim Hilpipre
Member Posts: 19
For some reason I cannot find the pressure drop chart for a GB142-45.
I need 8gpm on indirect side and will have 30% glycol.
Anyone know what the drop is (excluding indirect) or where I can find it?
Thanks!
Jim Hilpipre
Thanks!
Jim Hilpipre
Here is your answer
Call 1-800-Buderus.
Darin0 -
Jim, I have a GB 142-30 And the boiler headloss is 9ft. Call Buderus for the info, it's not in the book.
John M0 -
John M0 -
Thanks for the reply I did find the answer I needed, would be nice if it was published in the applications or IOM though.
Jim0
- 85.7K THE MAIN WALL
- 49 Biomass
- 69 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
