Need input from all the Pros here
mel rowe
Member Posts: 324
I would greatly appreciate it if each of you could spare a few minutes and read through enough of the thread "Heat Loss doesn't match Heat Load", and choose which replacement boiler capacity option you would recommend.
Thank you.
Thank you.
I have
as of noon or so. I am for the lower system.0 -
Not clear, which option did you mean?0
- 120 Geothermal
