Dropped the SMART!
scott markle_2
Member Posts: 611
I was told that because of the way the inner tank hangs it is important to transport it in the vertical position to avoid stress on this connection point.
I would imagine that the worse possible impact would be if it was being carried horizontally and the bottom end was dropped.
Slipped outta my hands!
Hey all:
Dropped a new SMART 50 while moving it into the basement. Loud clang and some dented plastic. I know I'll have to just hook it up and see if it's leaking, but does anyone know if these things are easily damaged? Stainless steel shouldn't be affected that much...?0 -
why were you?
Why were you carry the car down the stairs?0 -
No stairs..
Just moving it in the basement out of the way of construction.0
- 167 Indoor-Air Quality
