I've just about seen everything now.
The Boiler Dr.
Member Posts: 163
was a 15 or 20 section steam rad that some one took the time to drill and tap for 1/8 brass nipples then connected each of the nipples using 1/4 soft copper and compression fittings. Talk about patience as all the nipples lined up. I considered it more a work of art than anything. Now I really wish I had pics of that.
How to turn a steam rad into a water rad.
Drill holes in each column, insert metal siding screws, but do not tighten yet. Fill rad with water until all air has escaped and then tighten screws.0 -
Why did I not think of that
What a great way to kill your radiators, Priceles0 -
Hey
They only leak a little when the rad is cold.
Might better have left it and let the top be for expansion.0 -
Isn't that what the rubber washer is for? I have several steam rads that were drilled & tapped to be HW rads. Proper vents installed, likely when system was converted from steam to HW...
TimJust a guy running some pipes.0 -
This type of rad
doesn't circulate water very well, since the sections are not connected across the top. So it might not give off the heat a proper hot-water rad would.
I'd say that one has really been knuckleheaded.
- 167 Indoor-Air Quality
