Change Out - DF
Paul Cooke
Member Posts: 181
Dan
I thought that looked like the 22. We just did 2 different homes with the #11's and yours looked wider.
So far, the clients love these systems. Great comfort with a well insulated home.
I've also started noticing lots of Dianorms in some foreign films that I have seen lately.
Boiler Repl.
Here is a change out we did recently in North Arlington. Brian Golden and his crew replaced an old Hydro-Therm with this Viessmann Vitogas 50. It was in a tight space and this V did the trick.
Brian also added a couple of Dianorm panel radiators in the basement and installed Danfoss TRV's on the cast iron rads. -DF
You folks
do AWESOME work Dan!
Very nice!
Mark H0 -
DF
Great Job!0 -
Nice job Dan and crew
Gotta love the KISS method where needed. Straight forward and neat. Nice work guys. Chris0 -
Nice Job
What a sweet job, you guys are masters.0 -
Thanks
Thanks all for the comments. Brian makes my job easy. I give him the boiler/materials and he brings back a check. What's not to like? -DF
Dianorm
Is that a double-wide Dianorm? Also wondering what kind of pipe you used to connect to it.
Looks great.0 -
Dianorm
Paul, that is a Dianorm Style 22 panel radiator. They are connected using the "H"-style valves to 5/8 Multi-Cor. Sometimes Brian will use 1/2" copper stubs which necessitates a different style adapter fitting. Thanks for the kind words. -DF
Real nice
Your crew is top notch Dan . I like the compact design of the Vito . Perfect for a tight install . What was in there before ? Any pics ?0 -
Ron
Thanks, Ron. Obviusly the term "tight" is relative. I don't know how you do some of your jobs!
No "before" pics - my guys were too quick with the demo. -DF
- 120 Geothermal
