small sealed combustion boiler
Jim Wy.
Member Posts: 43
I've got a small staple up job to do that only requires 80MBH. I'd like to try to be competative using a sealed combustion l.p. boiler but not a tankless waterheater.Any suggestions would be helpful. thankyou
Embassy
BMS or AXIA...they can do hot water w/ tem but you don't have to use them.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
