Fuelless Heater
Mr. Blonde
Mr. Blonde Member Posts: 38
http://www.youtube.com/watch?v=yh_-DUKQ4Uw
----Is this for real?
  • bigugh_4
    bigugh_4 Member Posts: 405
    the Electric motor
    Is the FUEL!!!
  • exactly
    Heat = Energy
    convert Electric Energy to Heat Energy through the rotation of the motor and impellor (if you can call that huge drum a impellor).
    What confuses me is they are claiming to be able to magnify the energy used and are claining better then 100% conversion factor. This is in direct conflict with what we know as the First Rule of Thermodynamics.
    Very interesting indeed.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,874
    Rules..
    are made to be broken, no? :-)
    But still, you've got to ask your self, if it IS 170 % efficient, why has EVERYONE adopted it for heating applications? Heck, it could be used for cooling applications as well thru lithium bromide absorption cooling.
    I think it is being suppressed by the government because it would cause such an uproar in the energy production industry. I'm guessing the gas and oil companies are snatching up the patents and prototypes and locking them away for perpetuity (said with tongue FIRMLY planted in cheek)...
    I do remember seeing a pump back at the WILO factory, in their lab that was being used to heat their shop facilities, so cavitation heaters are for real, I just question their efficiency numbers...
    ME
