Mixing Valve for Radiant Heat
George_15
Member Posts: 24
I have a 6unit apartment building with 6 zones and 6 booster pumps.... one for each unit. The 4 top units have baseboard heat and the 2 lower level units have radiant heat. These 2 lower units have the red Bell and Gossett pumps in the left of the pics. It looks like there is a mixing valve in line that comes up from the return and mixes with the hot supply line. I noticed that I had both the mixing valve and the hot supply line valve completely open all the way. Is there a recommended way to adjust these two valves for optimal heating without worrying about cracking the concrete? I was thinking with both valves open all the way I am feeding too much return water in there so I closed off the return valves slightly. Any input would be appreciated!
http://smg.photobucket.com/albums/v737/greekguy7/?action=view¤t=SP_A0012.jpg
http://smg.photobucket.com/albums/v737/greekguy7/?action=view¤t=SP_A0013.jpg
http://smg.photobucket.com/albums/v737/greekguy7/?action=view¤t=SP_A0014.jpg
http://smg.photobucket.com/albums/v737/greekguy7/?action=view¤t=SP_A0015.jpg
http://smg.photobucket.com/albums/v737/greekguy7/?action=view¤t=SP_A0016.jpg
By those pics...
you have no real control there and I don't see that any methodical approach or thought went into the installation.
That being what it is, I believe there is no good answer to your question without a site consultation by a qualified installer.
Sorry for the negative reply. Perhaps someone here will disagree.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Thanks... I know what you mean about the way its currently set up.
Is there a specific high temperature to avoid any damage to the system due to cracking the concrete and the radiant piping?0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
