32mm pex-al-pex fittings
Chuck_39
Member Posts: 1
I have a contractor looking for (2) fittings to go from what we believe is 32mm pex-al-pex to 1" copper. The pipe says made in Germany and that's all we have to go on. Please help if you know where we can attain these fittings.
Could be uponor MLC, it's made in Germany, it's white (with a VERY slight aluminum color that seem to shows thru the outer layer)
maybe this helps http://uponorhsdna.com/index.php?id=1100 -
conversion pex al pex fitting
http://www.amazon.com/gp/product/B00LZGZD9Q
http://www.amazon.com/gp/product/B00LZHYAZ80
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
