glycol questions...
hot_rod
hot_rod Member Posts: 26,645
is the only waty to tell PG from EG. Several glycol manufacturers have confirmed that.
Also you can mix PG and EG, but you end up with a solution of unknown toxicity. EG is a better transfer fluid, and also breaks down in the enviroment quicker than PG (1 less carbon) But the higher toxicity make it too risky for most residential applications.
EG was used as de-icers, may still be, in many areas as it would break down faster in the bio ponds before going down the drain, from the research I have done. I see most airports now label the spray trucks PG, I've been keeping track with all my flying time and boredum associated with waiting on runways :)
Interestingly glycol recyclers mix PG and EG all the time. Many of the automobiles now use PG glycols. When that fluid is drained to recycle at Lube joints, dealers, repair shops, etc it all goes into the same drum. Rarely does a mechanic know what fluid he is draining.
As you know the fluid has 3 different protection numbers. If absolute burst temperature is what you are looking to protect for, use the last number. If slush, but no pump-abilty is enough, use the middle number.
Those protection numbers vary from brand to brand, but also from version to version. As you can see from this attachment HD or heavy duty glycols have different numbers.
hr
  • Timco
    Timco Member Posts: 3,040
    How does one tell the difference between ethly and prop glycol? I am servicing a system with red glycol. Second question is do you add glycol until it will protect against the design temp in my area? (3* design temp here) Glycol tests to +5* ethyl type and +12* prop type with a refractometer, now I need to know what I am using!
    Thanks, Tim
    Just a guy running some pipes.
  • Mark Custis
    Mark Custis Member Posts: 537
    One is food safe the other is very toxic
    I use paper test strips for PH and protection values. I have never tried a tester from auto zone on my systems.
    Color is just that, "don't drink this", I am stumped. Which is why I come here. I get to see questions and answers about stuff I do not know.
    I know someone here is a chemist.
  • Timco
    Pink glycol was very sweet when I mixed it with my soda...kidding. This stuff irritated my hands so I am sure it is ethylene. Not sure what freeze point to take it down to...
    Tim
  • Douglas Hicks
    Douglas Hicks Member Posts: 69
    Propylene glycol is available in USP grade (United States Pharmacopoeia 96.9% )or non-USP. We normally use USP in fire sprinkler systems. Teh price difference is less than $1.00 per gallon.
    I asked the same question as you did, and I did not get an answer. I called UniVar, & did not get a question.
  • Drew_2
    Drew_2 Member Posts: 158
    Glycol
    Timco
    Spectral analysis is what we have used in the past. Testing is pricey.
    Drew
    Noble Company
