how could this be?
Jim_64
Member Posts: 253
but even the aluminum is corroded on the one, with some sort of rust-red deposit
how could this be?
two identical pumps installed in a boiler system on the same day; 8 months later, one is completely corroded and leaking, the other still looks new0 -
1 made on Thursday and other made on Friday?0 -
Look above the corroded pump you may find a leak. f you want to find the leak look at the floor for the puddle not the sky for the leak. Unless it is a high wind basement go plumb straight up and theres the source.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
