steam heat
peter petruzzi
Member Posts: 1
one radiator spits out one gallon of water in 24 hour period. Recessed radiator. No valve, pitched ok. Return lines are below water level at boiler and the main has good pitch. Help what could be the cause.
Water
From where is it spitting the water? The vent?
Are the mains insulated? Is the radiator the lowest one on the main?
Pics?0 -
could also be...
a dirty system. kpc0
- 167 Indoor-Air Quality
