infloor heat
just installed wirsboro quik trak panels for a basement heat zone using existing 80 gallon power vented water heater with heat exchanger to isolate potable from domestic water the existing potable side had a recirc line installed w/ no pump just check valve before it renters cold water side my problem lies w/ the recirc lione just stopped working it is now taking a long time for system to get hot water to fixtures any reason or help would be great heat system works great also on potable side i have a bronze 007 circ flowing potable water through heat exchanger and im using tapping provided on water heater for space heating
