Valve packing, one pipe steam
bob young
Member Posts: 2,177
graphite packing works well but some gents prefer teflon. fielders choice. lampwick works too but might not hold up as well. molded washers might be available if you can spec. out fig. # of valve
We have hundreds of one pipe steam radiator valves in service, and one vexing problem is the frequent loosening of packing nuts and the attendant water damage. What is the best packing to use, quantity, installation technique, etc? There is no mention of this small thing in any of our reference books.
These valves are in apartments and are operated by the residents. One pipe means lots of action. No such problem in the two pipe systems.0 -
I use the teflon packing thats about an 1/8 inch in diameter. I wrap it clockways until I have enough to fill the space under the packing nut, but without having to force the nut on. Works like a charm for me.
The angle valves on the floor shouldn't de fiddled with for controlling heat to the radiator. Thats what the air valve is for. How many apartments per boiler is there?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"There was an error rendering this rich post.
