boiler zones
monte_2
Member Posts: 2
no matter what i do, i cant get my living room to cool. its stuck on 72 degrees, even tho the thermostat is on 62. i even changed the thermostat.
It's probably not a thermostat problem. It sounds like the thermostat isn't controlling the zone. Try to find out of the zone valve or the zone pump is stuck open. Or, is there another source of heat?0
- 117 Geothermal
