Steamhead and Gordon, Many Thanks!
chemeclimber_3
Member Posts: 1
Great Job on the vapor Smith G8 install. For the first time in 8 years, I walked down to the living level (where the new radiators were installed) and it was not cold. Usually, half of this level is cold....not any more! Also, not a sound from the system (banging, poping,...) other than the burner.
All homeowners, do yourself a favor and contact "All Steamed Up" if you have issues with you steam heat.
Homeowner,
Homeowner,
great job guys!!
nothing sweeter than when the homeowner sings your praises!!
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
Thanks, Joe
you and your family really went out of your way to make it easy for us. You will always be one of our favorite customers.
Just over one ounce..... that's all it takes to keep a family comfortable.
Vaporstat setting
Steamhead,
If one ounce fills the rads what do you set the vaporstat to? Thanks.
In this case
I left it set to cut out at 5 ounces and in at 3. There's enough "B" dimension for that. It will probably never trip unless they shut off some radiators.
"Steamhead"
- 167 Indoor-Air Quality
