Hot water lines crackling
Tim_5
Tim_5 Member Posts: 37
It is in the hot water supply line, saeems to be in the location of a tee or a 90, the water temp leaving the boilet is at about 140 and returning at 125-130 degrees. No relief valve discharge.
  • Tim_5
    I seem to get a crackling sound coming from my hot water supply line, it seems to be coming from either a tee fitting or a elbow. i think it is some air bubbles trapped, any comments
  • Big Ed_4
    Big Ed_4 Member Posts: 3,369
    Death Rattle ?
    Is it when the hot water heater is building up ? Or are you talking about your boiler hot water supply line?? Does it sound like water boiling ?
