EVER HEAR OF \"BELKNAP RADIATOR VALVE\"?
bill nye_3
bill nye_3 Member Posts: 307
of the caps lock key , it is on the left side of the keyboard
  • MIKE SARSFIELD
    MIKE SARSFIELD Member Posts: 1
    SINGLE SIDE HOT WATER RADIATOR SUPPLY AND RETURN
    I'VE FOUND A STUMPER OF A FITTING(BELKNAP VALVE). A CUSTOMER WITH A PREVIOUSLY REMOVED H/W RAD FROM A THIRD FLOOR RENOVATION DONE IN THE 70'S WOULD LIKE IT RE-INSTALLED. ITS A 6 SECTION, 3 COLUMN, 40" TALL BEAUTY. BUT THE COMBO VALVE IS MISSING THE HALF UNION NUT AND TAILPIECE FOR THE RETURN SIDE. NOT SURE IF IT NEEDS SEPERATE S+R FROM BASEMENT OR TIE INTO EXISTING 2ND FLOOR WITH A COUPLE OF TEES. I DON'T THINK THE OPPOSITE END EVEN HAS A PLUG TO REMOVE.
    THERE ARE OTHER RAD'S INSTALLED AND WORKING FINE. SEEMS TO BE ALMOST LIKE A MONO-FLO SYSTEM. ANY THOUGHTS WOULD BE APPRECIATED.
