Carlin interupted ignition oil primary problems
Matthew Grallert
Member Posts: 109
I have a Carlin interupted ignition oil primary model 60200-002. Beckett model AFG oil furnace. Having thermostsat problems. Used a digital volt meter reading 79 volts. Should I replace this carlin with the same unit or use something better? Could there be some other issue affecting this unit? The unit looks pretty new. I bought the house 2/08 On the unit somebody with a marker wrote 1/08. I have no idea who serviced the furnace last nor could I get that info. There are no stickers from any service company on the boiler.0 -
Read this
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
I have to look at it tommorrow. From memory I'm pretty sure it was wired correctly. Are there any other suggestions? Thanks for the help.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
