Some Pics of work lately
ddlong1286@yahoo.com
Member Posts: 139
Hi all,
Took some pics today and downloaded to the computer. Noticed other pics and thought I'd post some since the A/C seems to be slow.
The first ones are from milk collection stations for the Amish. Replacing the accumalators/heat exchangers on the condensing unit. Will also be removing the quick connect on the left line set on the tank. Brazing stainless to copper!! Any suggestions??
The next pictures are leak repairs on an Aaon rooftop. Tee had a crack on the bottom and the evap coil had a leak also. Love leaks in end sheets!!
And lastly, good ole factory workmanship. Had to replace a cond. coil in a less than one year old rooftop and found the drier in backwards.
Hopefully your staying busy out there!
Don in Moberly Mo
Don in Moberly Mo
Don
Thanks for shareing.0
- 50 Industry Classes
