aluminum oxidization in pex
van_8
Member Posts: 12
Has anyone had aluminum oxidization in a pex loop and found a way of cleaning it out? Thanks for your help.
Curt v
Curt v
You might try Hydro-Solv 9100 cleaner from Rhomar to clean the system and then the Pro-Tek 922 inhibitor or RhoGard glycol to help prevent it from recurring. You can find tech sheets for these products at www.rhomarwater.com.
Dwight0 -
Why the Oxide? what's your PH at?0 -
The ph was to high due to well water & glycol didn't check it right away my screw up.0 -
Yes as Dwight said "Rhomar to the rescue".
That is what i have used, you may import your system Fluid if you PH is off.
but then again you shall call the guys from Rhomar they know better.0
