Baseboard inside corners
Robert O'Connor_12
Member Posts: 728
Hi Wall!
I'm installing baseboard and the inside corners I need are of a different angle than what I purchased. The actual angle is (apox.)122 degrees. Has anyone run into such a problem and what did you do? The customer is a wee bit fussy and I know if I cut them there will be a slight gap.
Thank You!
Geo
Thank You!
Geo
Inside Corners
I don't know what type of baseboard you have, but I know Argo Lo-Trim Baseboard has 60° inside corners. Maybe you can order a 60° corner?0 -
custom angles
Slant fin makes an inside corner you field cut. Check out their website http://www.slantfin.com/documents/341.pdf.
Wild Rover0 -
custom corners
We made some custom 150 degree corners with Haydon 135 degree corners. We straightened them out very carefully, then cut and rebent them with a "hand" brake. They came out great. I've also used the Slant Fin corners that you don't have to straighten, but if you're committed to another brand buy the 135 degree corners & make your own.
(buy one extra for practice)
inside corners
I appreciate everyone's replys
Thank You!
G0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
