Timer for Recirculating pump
Andy_17
Andy_17 Member Posts: 30
Had a Knight 8o & Indirect tank w/ recirculating line installed last year, Love It!
Would like to improve the gas usage a little more, by installing a timer on the recirculating pump. Is there any down side to installing a 7 day timer w/ multiple on/ off settings? IE- 6-9Am on, 9am-5pm off, 6-10pm on ETC. Figure might as well squeeze a little more efficiency out of the system.
Thanks
  • Big Ed_4
    Big Ed_4 Member Posts: 3,344
    Timer and System Loss
    Setting a timer to charge the lines on peak demands is a good way to save. And Insulating the lines are also needed to save energy and meet Federal energy codes .
  • The only downside
    that I can think of is waking up at 5 am (or any other "off" hour) and have to wait for the hot water.
  • Doug_7
    Doug_7 Member Posts: 266
    Timer or Motion Sensor ?
    Another method of control is a motion sensor (or switch) to turn the DHW recirculation pump ON. Would need a motion sensor located wherever you need instant hot water - like at a shower but not necessarily at a sink. See:
    http://www.toolbase.org/Technology-Inventory/Plumbing/hot-water-recirculation
    or google: hot water recirculation motion sensor.
    Constant DHW recirculation wastes electricity to run the pump and wears out the pump - but more importantly it wastes heat that is emitted from the constantly hot pipes.
    Which control method is best depends on your situation.
    Doug
  • mtfallsmikey
    mtfallsmikey Member Posts: 765
    How about
    A nice 7-day programmable timer, like the Intermatic ET-1700 series..can support up to 14 events daily.
  • paul_79
    paul_79 Member Posts: 91
    pump timer
    i have had good luck with the grudfos UP10-16 recirculation pump it has a built in timer and a aquastat
