Baseboard inside corners
Hi Wall!
I'm installing baseboard and the inside corners I need are of a different angle than what I purchased. The actual angle is (apox.)122 degrees. Has anyone run into such a problem and what did you do? The customer is a wee bit fussy and I know if I cut them there will be a slight gap.
Thank You!
Geo
